1. AC Question's Avatar
    i have audio -ie songs in the computer. this has to be transferred to sd card.
    the transfer is ok buut it makes its own order- not the one as i have copied.literally it jumbles all
    what should I do /
    08-19-2014 12:19 AM
  2. UJ95x's Avatar
    Are they music files or other audio like voice recordings?
    Where are they showing in incorrect order? Are you looking at them in a file explorer or a music player app?
    08-19-2014 12:23 AM
  1. Replies: 3
    Last Post: 08-21-2014, 03:19 PM
  2. How to get the most out of my g3
    By G3Chece in forum LG G3
    Last Post: 08-19-2014, 05:14 PM
  3. Auto App Organizer works in Android KitKat 4.4.2
    By Boris Novich in forum Android Apps
    Last Post: 08-19-2014, 01:34 AM
  4. Replies: 1
    Last Post: 08-18-2014, 10:11 PM
  5. Can't install Google Apps after upgrading to CM11
    By popcynical in forum Samsung Galaxy S3
    Last Post: 08-18-2014, 09:37 PM
