Results 1 to 8 of 8
    Default Note 2 Weak WI-FI signal (external aux antenna)
    So I bought a note 2 from a friend but i do not seem to get very good wifi signal. It works fine if im in my room next to the router but as soon as i step out i either get disconnected or lose the wifi signal. I took it to a cell phone repair shop and they told me that I should look for an external antenna that connects to the aux port. He said that, that could boost my wifi signal but i can't seem to find it.
    So could someone help me find this Aux Antenna?
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default Re: Note 2 Weak WI-FI signal (external aux antenna)
    Welcome to AC
    Are you having the same issue with other devices when connecting to WiFi? If so, it is your router causing the problems and not the phone.
    As for improving connection, you can look for WiFi repeaters or signal boosters on eBay, Amazon, etc. They're fairly easy to find
    I'm not having any other issues connecting to my wifi using other devices. I have my ps3, ps4, tv, and laptop connected to my wifi, i also used to have a galaxy s3 and that one seemed to connect to my wifi router without any problems. Also when i have friends over their phones connect to wifi and stay connected even when we go to my basement they still get 2-3 bars but my phone doesn't even connect.
  4. #4
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by captain-penguins View Post
    Hmm. So it is most likely an issue with the Note. You said it works well when you have good signal strength, so getting a Wi-Fi repeater installed could help with the range issue.
    Sent from my Galaxy S4 running SlimKat 4.4.4
    Would updating my phone help with this issue?
  6. #6
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    If there is an update it's worth a try, but if it's a hardware issue the update won't do anything.
    Alright, thanks a bunch for the help!
  8. #8
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    No problem
    Let me know if there is an update and whether or not it helped.
  1. [APP][ROOT] Undeleter - Restore Files & Data [APK]
    By ftgg99 in forum Android Apps
    Last Post: 03-16-2015, 05:34 AM
  2. Does o2 switch 4G signal off in the afternoons?
    Last Post: 08-21-2014, 04:40 AM
  3. S5 or Note 3?
    By l No Use For A Name l in forum Samsung Galaxy S5
    Last Post: 08-20-2014, 01:13 PM
  4. Netflix from my Galaxy Note 8.0 to my tv.
    Last Post: 08-19-2014, 04:57 PM
  5. Galaxy Note Pro 12.2 Disable Mail Badge
    Last Post: 08-19-2014, 02:44 PM
