1. chan139's Avatar
    The phone screen is having random auto touch repeatedly. It clicks into apps randomly and keeps clicking in. The phone could hardly be used.
    The repairman at service center diagnosed it as screen problem, but he was uncertain. The problem might persist after screen replacement.
    Much appreciated if anyone could point out the root cause and suggest any solution. Thank you.
    Since this is my first thread, I'm unable to post a link here. I've recorded the problem in youtube with the title: Defective screen LG Optimus G (E975)
    08-19-2014 11:27 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I agree, it's probably a problem with the digitizer. But make sure the screen is completely clean, since various kinds of gunk might cause some screen issues. Also, are you using a screen protector? See what happens if you remove it.
    chan139 likes this.
    08-20-2014 12:08 AM
  3. chan139's Avatar
    Thanks for the suggestion.
    I do not use screen protector. I've tried to clean the screen yet the problem still there . The auto touch is very persistent on the area at the middle of digitizer, instead of a particular point.
    08-20-2014 01:22 AM
  4. B. Diddy's Avatar
    Yeah, that sounds like a hardware defect.
    08-20-2014 01:42 AM
  5. Tadas Tamosauskas's Avatar
    I had the same problem with my LG E975 and I tought this is hardware problem. But about week after problem started I smashed my phone screen. I changed screen and problem disappeared!!! And one more thing: One problem from then I bought this phone: problem of screen auto-touchig appears then phone is charging Does anyone have this problem too. PS I hope it works for you, Good luck
    04-01-2015 11:37 AM
  6. Suzanne Elmouhager Basha's Avatar
    hi im having the same problem. can someone tell me if changing the screen helps.
    06-15-2015 10:47 AM
  1. Lg optimus g pro front camera not working.
    By Dylan Benedetto in forum LG Optimus G Pro
    Last Post: 11-13-2016, 09:26 AM
  2. Replies: 9
    Last Post: 08-25-2014, 06:31 AM
  3. charging rate for lg g3
    By Bob Wilker in forum LG G3
    Last Post: 08-20-2014, 02:15 PM
  4. How to install software update on rooted lg g3
    Last Post: 08-20-2014, 02:41 AM
  5. Galaxy S4 Active (Hardware?) Problem
    Last Post: 08-20-2014, 12:15 AM
