Results 1 to 19 of 19
Like Tree9Likes
  • 4 Post By B. Diddy
  • 4 Post By SpookDroid
  • 3 Post By Golfdriver97
  • 1 Post By Slashyou
    dmargareth's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Help. Im new someone help me . My battery is getting hot when i charge it. HELP!!!
    Hi ,i have phone samsung galaxt ace 3 and i buyed it a month ago. My problem is what can i do? my battery is getting hot when im charging it. and when i charge it . it stop cause of battery temperature is hot. What can i do? please help. Thanks.
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,850 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Help. Im new someone help me . My battery is getting hot when i charge it. HELP!!!
    Welcome to Android Central! That's often a sign of a failing battery. Try a new battery. You can confirm problems with your current battery by removing it, placing it flat on a table, and trying to spin it. If it spins freely, it's bulging in the middle, which confirms failure. But it's still worth trying a new battery even if it doesn't spin.
  3. #3
    SpookDroid's Avatar
    Posts
    Global Posts
    11,672 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That's never a good sign. Either your charger is deffective or your battery is no bueno. First try using a different charger, and if it doesn't work, take the phone back to either get a warranty replacement or have it fixed. HOT BATTERIES ARE DANGEROUS! Fire hazard.
    It can also mean that something in the charging circuit of your phone is wrong and is causing a short inside. This, of course, is a fire hazard as well.
    dmargareth's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi B. Diddy and SpookDroid . Thank for the help. i removed my battery ,sims,and memory card and let them cool . And when i charged it ,its back to normal again. Thanks for the help
  5. #5
    Slashyou's Avatar
    Posts
    Global Posts
    842 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by SpookDroid View Post
    Paranoid much? a phone wont kill you at the worst it leaks and breaks the phone.
  6. #6
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,056 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Quote Originally Posted by Slashyou View Post
    I am inclined to disagree. There have been reports of severe burns from cell phones.
    One example: http://www.dailymail.co.uk/health/ar...burnt-pig.html
    SpookDroid, B. Diddy and UJ95x like this.
  7. #7
    Slashyou's Avatar
    Posts
    Global Posts
    842 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Golfdriver97 View Post
    One example: Exploding Samsung Galaxy phone leaves teenager with third degree burns and smelling like a 'burnt pig' | Mail Online
    I disagree they cant the s3 was burned or something.
  8. #8
    dpham00's Avatar
    Posts
    Global Posts
    24,790 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Someone has been killed while charging a phone. Granted they were using a third party charger.
    Sent from my LG G Pad 8.3
  9. #9
    Slashyou's Avatar
    Posts
    Global Posts
    842 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dpham00 View Post
    Yea probably but that wasn,t a charger but some paper clip put in the socket and cable attached to it as the person lost the usb to wall thing to she used paper clips.
    Sent from my iPhone using Tapatalk
  10. #10
    Slashyou's Avatar
    Posts
    Global Posts
    842 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Help. Im new someone help me . My battery is getting hot when i charge it. HE...
    [QUOTE=Slashyou;3849555]Yea probably but that wasn,t a charger but some paper clip put in the socket and cable attached to it as the person lost the usb to wall thing to she used paper clips.
  11. #11
    SpookDroid's Avatar
    Posts
    Global Posts
    11,672 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Never said it would kill you But it is still a fire hazard, and the resulting fire if something else fuels it CAN. Let's play "Final Destination" here, shall we? You leave your faulty-phone charging on your night stand. It starts to heat up. You don't notice because you're asleep. Then it starts to shoot sparks because of the molten soldering iron causing shorts all over the place. The sparks ignite your bed sheets and the curtains on your window. By the time the phone finally explodes with that loud bang, you wake up with a fire all around you. Plus, the glass shattering from the battery bursting caused flying debris to cut into your skin. A second burst just as you wake up sends a flying shard right into your eye.
    Gruesome enough? It's not paranoia, it's plain, common sense.
  12. #12
    Posts
    Global Posts
    33,056 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    This can trigger what is known as a “thermal runaway” in which the battery overheats and can burst into flame. From : http://www.economist.com/blogs/econo...st-explains-19
    lithium ion battery fires not only burn extremely hot (up to 1000 degrees fahrenheit), but can explode, sending chunks of burning metal across the room. From: http://www.techlicious.com/blog/the-...ion-batteries/
  13. #13
    Slashyou's Avatar
    Posts
    Global Posts
    842 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Plain htc sense 6.0 nah but thats Very unlikely most of the time they swell up but not more. i got a swollen iphone 3gs from criagslist and i fixed and im tapatalk,n on it right now
  14. #14
    Slashyou's Avatar
    Posts
    Global Posts
    842 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah but thats if you burn it i burned a one before and it just burned nothing more no ones gonna get hurt from a phone battery.
  15. #15
    Slashyou's Avatar
    Posts
    Global Posts
    842 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    But yeah id say your paranoid
  16. #16
    B. Diddy's Avatar
    Posts
    Global Posts
    77,850 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    There's a difference between being paranoid and being careful. Various laptops have also had issues with batteries overheating and melting or catching fire. If the phone's battery is severely overheating on a persistent basis, why take the risk? The battery is probably failing anyway. Get a new battery.
  17. #17
    Slashyou's Avatar
    Posts
    Global Posts
    842 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by B. Diddy View Post
    I know a person with a macbook that swell up Lol it looked like this. Click image for larger version.
    Not hes though but yea i got your point
    B. Diddy likes this.
  18. #18
    B. Diddy's Avatar
    Posts
    Global Posts
    77,850 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Holy moly, that looks ugly!
  19. #19
    Slashyou's Avatar
    Posts
    Global Posts
    842 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah it was crazy it was working 100% 1 sec later BANG! it just popped and was working 0% even the hardrive was broken LOL
  1. WiFi on even when off?
    By agknight73 in forum HTC One M8
    Last Post: 08-24-2014, 12:04 PM
  2. Help Needed - Unlocking Sprint Samsung Note 3 To Use With AT&T
    By GoProDavidLe in forum Samsung Galaxy Note 3
    Last Post: 08-22-2014, 10:39 AM
  3. Note 3 buggy charging problem
    By Kay Ray in forum Samsung Galaxy Note 3
    Last Post: 08-20-2014, 07:53 PM
  4. What's missing from App reviews is,
    By mawil1013 in forum General News & Discussion
    Last Post: 08-20-2014, 04:05 PM
  5. sound tile help
    By indiane in forum OnePlus One
    Last Post: 08-20-2014, 01:33 PM
