Results 1 to 5 of 5
    AndroidDisectorGeek's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question Please Help Me!! LG Optimus Q lgl55c Help!!!
    *Okay, before I explain what is going on with my phone I just want to say I am good with phones and understand them I just have trouble sometimes with them, which everybody does, but everything I know I learned on my own.*
    * PHONE DETAILS- LG OPTIMUS Q LGL55C, ANDROID VERSION 2.3.4*
    * Also will not update with wifi. Every time I try it turns off wifi and I do not have service, anyone know why it wont update over wifi?*
    *Before we start, my port on my phone where the charger goes into is completely fried,(We will not get into that discussion... Lol), So no USB work.*
    I have a LG Optimus Q lgl55c. I know a lot about root, and as you can assume since I said that, my phone is rooted. I successfully rooted my phone, that was no problem, but I started to look into more about what the phone is actually capable of. I looked into it and did some research. What I found out is I can go deeper with my phone and have a better user friendly experience with it. ROMs!!!! We all know and love them, but what I actually learned about is unlocking the bootloader. I know this is a long thread but I am sure one of you tech geeks can help me. Well as you read above my USB port is not functioning so I can not unlock the bootloader from a PC. Also the reason why I am bringing this up before I get into the main subject is because I have no idea if this has anything to do with my biggest problem. I have no clue what version my bootloader is right now, so I do not want to use the ez-unlock app which only supports certain versions of bootloader( I do not want to brick my device ). My first topic question- "Is there any way to unlock my bootloader without a PC and have a slighter chance of getting bricked?"
    On forth to the main problem!!!!!
    ROMs are the best thing in my opinion on mobile phones. I did some research and learned about flashing ROMs to change the OS and also flashing custom recoveries such as ClockWorkMod. What I did, since I can not use USB, was I researched some ways to install or, more commonly know as, flash ClockWorkMod onto my phone.The most common way I found was to install ROM Manager from the Google Play Store and flash it onto your device from there. I did all of that correctly but when I click reboot to recovery or go there manually I always get the stock recovery boot screen. I also tried the rename the files method, but the files that I was suppose to rename was no where to be found. I have tried so many things. I really want to flash ROMs onto my device. So my next question is- "Does this have anything to do with my bootloader being locked?" "Am I doing something wrong?" "Is it possible to do without a PC?" -and last but not least-"Does those missing files have anything to do with it?"
    So basically my main problem is-
    Is it possible, if yes, am I missing anything I have not done?
    Reply ASAP, Yours Truly AndroidDisectorGeek!
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Default Re: Please Help Me!! LG Optimus Q lgl55c Help!!!
    Welcome to AC
    OK, hope I didn't read anything wrong...
    So your phone doesn't update over WiFi? But you're not having issues with anything else when on WiFi correct? In either case, it's possible that your device just doesn't support any newer versions of Android, so there's nothing to update to.
    As far as the recoveries and ROMing, you're going to have to get the bootloader unlocked. If your USB port is bad, you're not going to be able to use any methods that use the PC, which as far as I know is the only way of unlocking the boot loader.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well You read correctly, but would there be anyway to take the phone apart and fix the port?
  4. #4
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Kitkat
    Default
    Quote Originally Posted by AndroidDisectorGeek View Post
    Hello. You could try to take it to a repair center, or see if a store online has the USB port for your device. From there, you'd probably have to open the phone, take off the old USB port, and then put in the new one.
  5. #5
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Kitkat
    As far as unlocking the bootloader, I agree with UJ95x. You'll need a PC to unlock it, as well as to flash files.
  1. Replies: 18
    Last Post: 08-23-2014, 02:17 AM
  2. Help Needed - Unlocking Sprint Samsung Note 3 To Use With AT&T
    By GoProDavidLe in forum Samsung Galaxy Note 3
    Last Post: 08-22-2014, 10:39 AM
  3. Need help: Need a new carrier ASAP
    By chustle925 in forum Ask a Question
    Last Post: 08-20-2014, 04:47 PM
  4. sound tile help
    By indiane in forum OnePlus One
    Last Post: 08-20-2014, 01:33 PM
  5. LG Patents Device That Looks An Awful Lot Like an iPhone
    By Ry in forum General News & Discussion
    Last Post: 08-20-2014, 01:11 PM
