Hi all,
I have been trying to search for a solution to this and haven't found one yet. I've had my S4 since January and a few weeks ago got my first bluetooth ear piece. In the past little while I've had a weird problem where my phone will ring when someone calls, but when I pickup I hear nothing and they hear nothing. I disconnect the call and can hear the little disconnect sound. I will try to call back, hear the connect sound and the phone rings on the other end, but I don't hear ringing or the person calling. While this issue occurs I can't get the phone back to it's normal state unless I reboot the phone. I tried disconnecting/turning off bluetooth while in this broken state and I can never get the audio back on a phone call. All other sounds work!
I did some testing and found that when the bluetooth is paired it takes about 3 calls out for my phone to have this behavior. I tried this with another bluetooth ear piece (different brand) and the same issue occurs.
I'm not sure what else to try besides a factory reset, which is the last thing I want to do. Does anyone have any suggestions?
