1. Radha's Avatar
    I'm using GT-N7105 Samsung note 2 model problem in screen lock I cant change to only swipe lock please help me now I used number lock
    08-21-2014 12:40 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are Slide Unlock and Pattern Unlock greyed out in the options? Is your phone encrypted? If so, you have to use a password or PIN unlock.
    08-21-2014 12:46 AM
  3. UJ95x's Avatar
    Welcome to AC
    So you are not able to unlock your device? Or you just can't change your security settings? If it's the latter, just remove your PIN and set up the swipe to unlock again.
    08-21-2014 12:47 AM
  1. Help Getting KitKat on my Canadian GS3?
    Last Post: 08-21-2014, 05:33 PM
  2. Replies: 12
    Last Post: 08-21-2014, 09:33 AM
  3. HELP!!!
    Last Post: 08-20-2014, 11:50 PM
  4. Galaxy S3 Soft Brick. Please help
    Last Post: 08-20-2014, 10:43 PM
  5. I bricked my phone like a noob. HELP!!!
    Last Post: 08-20-2014, 09:54 PM
