Color problem
A
AC Question
I have a Samsung s3 ,my phone's default color keeps changing and taking effects from the Retrica application.
I tried to uninstall retrica but nothing have changed please if anyone can help .
Thank you
Laurie Mika
4
still waiting for your reply
If you need more info,I discoverd that the brightness of the phone have gone higher than normal
I even tried to fix it from the settings and the brightness still no result
Is it the screen? should i need to change it?
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
Could you take a screenshot of the same notification panel now? It looks off but it's hard to tell how bad it is from a picture.
You said "before the damage." Do you mean you dropped your phone or something?
Sent from my Galaxy S4 running SlimKat 4.4.4
