1. AC Question's Avatar
    Rooted LG G2VS980 with Kingo Root and created data connection issue. No 4g connection at all. 3g in and out. Have tried all the data and 3/4g settings changes to no avail
    Any help appreciated
    08-21-2014 08:17 PM
  2. UJ95x's Avatar
    Welcome to AC
    Did you just root the device? Or did you flash a kernel/ROM as well? In any case, it's likely that one of the exploits broke functionality on your device since it was working fine in the past.
    08-21-2014 08:37 PM
  3. jeffrookie's Avatar
    ok , so what do I do to fix it>
    08-21-2014 09:14 PM
  4. UJ95x's Avatar
    I'd suggest unrooting the device and seeing if that restores it.
    Sent from my Galaxy S4 running SlimKat 4.4.4
    08-21-2014 09:45 PM
  5. jeffrookie's Avatar
    OK thanks. I started to try that but looks pretty drawn out and complicated. Can you recommend the best/easiest path to do that.
    thanks for your help
    08-21-2014 09:49 PM
  6. UJ95x's Avatar
    Which root method did you use?
    Is there a SuperSU app in your app drawer?
    08-21-2014 09:52 PM
  7. jeffrookie's Avatar
    I used Kingo Root. yes Supersu is installed. I tried using esfile explorer to unroot but it will not work on my phone.
    I also tried to unroot using the SUPERSU tool but that doesnt work either
    08-21-2014 10:03 PM
  8. UJ95x's Avatar
    What happens when you click full unroot from within SuperSU?
    08-21-2014 10:13 PM
  9. jeffrookie's Avatar
    it takes the command and starts the process and says "uninstalling please wait" but it just stays like that and never finishes the process
    08-21-2014 10:20 PM
  10. UJ95x's Avatar
    How long did you wait? I'd imagine that would take a bit of time.
    08-21-2014 10:21 PM
  11. jeffrookie's Avatar
    its been running for about six minutes now. will let it run longer and see what happens. could be I haven't waited it out.
    08-21-2014 10:26 PM
  12. UJ95x's Avatar
    Hmm. OK. Let me know how it goes
    08-21-2014 10:38 PM
  13. jeffrookie's Avatar
    ok ,SUPERSU would not do it so I downloaded a app called "Universal Unroot" and that did the trick. phone is unrooted but still have the connection issue. BTW I tried another sim card also and no change
    it toggles between 1g and 3g but never goes to 4g
    08-21-2014 10:44 PM
  14. UJ95x's Avatar
    Hmm, maybe it's a carrier issue? Do you have access to another phone to test if those are connecting to 4G.
    08-21-2014 10:48 PM
  15. jeffrookie's Avatar
    yes I already tested it with another line
    08-21-2014 10:52 PM
  16. UJ95x's Avatar
    At this point I'd suggest just taking it into a carrier store. Tough to help you out with something like this if I can't actually see the device. Hopefully they'd be able to get something worked out
    08-21-2014 11:08 PM
  17. jeffrookie's Avatar
    THANKS FOR ALL YOUR ADVICE AND HELP. finally got it working. was apparently a sim card issue.
    thanks again
    08-22-2014 11:42 AM
  18. UJ95x's Avatar
    thanks again
    Glad you got it working again. See you around the forums.
    08-22-2014 01:15 PM
  1. Galaxy S3 keeps connecting to gear but never gets anywhere!
    By snakehead404 in forum Samsung Galaxy Gear
    Last Post: 09-23-2014, 06:15 AM
  2. Replies: 2
    Last Post: 09-06-2014, 09:46 PM
  3. how much will the non-discounted Verizon Note 4 cost? $599 or $699 or more?
    By yourphonemyphone in forum Samsung Galaxy Note 4
    Last Post: 08-24-2014, 07:26 PM
  4. Ethics of Rooting
    By macaranaman in forum Android 4.4 KitKat
    Last Post: 08-24-2014, 02:11 PM
  5. Verizon Data connection issue after root with LG G2VS980
    Last Post: 08-21-2014, 08:38 PM
