+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Default Note 2 Intermittent Charging Issue
    I'm having a charging problem with the Note 2.
    Whenever I plug in the wall charger into the phone, the battery indicator starts blinking between charging and not charging, every split second. I have to restart the phone with the charger in it then it goes back to normal charging.
    This is getting really frustrating. Its not been rooted, but I'm unsure if its connected to upgrading the phone to Kitkat which I did recently.
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,850 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Note 2 Intermittent Charging Issue
    Welcome to Android Central! Does the same behavior occur with a different charging cable/plug?
    Try booting into Recovery Mode and wiping the system cache partition, which won't erase any personal data. This can sometimes correct various issues after a major system update. Reset: Samsung Galaxy Note II | T-Mobile Support
  1. Replies: 38
    Last Post: 09-18-2016, 01:48 PM
  2. Samsung Galaxy S3 mini hotspot issues
    By Vavalou90 in forum Ask a Question
    Last Post: 04-03-2015, 02:22 AM
  3. Verizon/Unlocked Galaxy Note 3 White
    By Bl00dRunzC0ld in forum Marketplace Archive
    Last Post: 08-24-2014, 08:52 PM
  4. Advanced options missing after upgrading note 2
    By Soli54 in forum Samsung Galaxy Note 2 Rooting, ROMs, and Hacks
    Last Post: 08-24-2014, 08:17 PM
  5. App download issue
    Last Post: 08-22-2014, 01:21 PM
