+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Default Problems charging S5
    Hello
    I bought a have a Galaxy S5. When I charge it, It starts charging fiew seconds, then it stops some minutes. It starts again and stop.
    I took the battery and put in another S5 and it charged properly. When I retounr to the first one, the problem continues. What can it be? (software? hadware?) What can be the solution?
    Thank you
    Mucas
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,957 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Problems charging S5
    Welcome to Android Central! It might be a problem with your charging cable, charging port, or internal hardware. Since your phone is new, I wouldn't waste any time and just bring it back to the store, asking for a replacement.
  1. Replies: 1
    Last Post: 04-06-2015, 02:41 AM
  2. wifi hotspot for my S5 with Verizon and unlimited data
    By Ed Ke6bnl in forum Ask a Question
    Last Post: 08-26-2014, 08:06 PM
  3. how to root galaxy s5 now that towel root doesn't work
    Last Post: 08-25-2014, 05:34 PM
  4. wifi problem on kitkat 4.4.2
    By Anjali Sharma in forum Ask a Question
    Last Post: 08-22-2014, 12:20 PM
  5. same problem with GT S-7562
    Last Post: 08-22-2014, 11:48 AM
