+ Reply
Results 1 to 8 of 8
    AC Question
    AC Question's Avatar
    Guest
    Default Battery icon with a little 'i' symbol inside?
    What is this grey battery shaped (in horizontal position) icon in the status bar (left upper corner) with a little 'i' symbol inside?
    I can't find answer to this question anywhere. Such icon doesn't appear in sonymobile's web page under "Status and notification icons overview" either.
    Android: 4.3
    Xperia M
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default Re: Battery icon with a little 'i' symbol inside?
    Welcome to AC
    Could you post a screenshot of it? It would make it a lot easier to identify.
    Sent from my Galaxy S4 running SlimKat 4.4.4
  3. #3
    Thank you for replay.
    Attached Thumbnails Attached Thumbnails Battery icon with a little 'i' symbol inside?-12.jpg
  4. #4
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by SxP12 View Post
    If you pull down the notification shade is there anything there?
  5. #5
    Good idea! Unfortunately it's not there anymore... I'll try to do that once it gets back (if it will do that).
  6. #6
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Alright. Let me know if you figure out what it is.
  7. #7
    It's a Power management tip. Offers to activate stamina mode. Thanks for help.
  8. #8
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Cool. Thanks for the heads up
    I'll remember in case it comes up again.
  1. Battery Saving Tricks
    By Omer San Gabriel in forum Samsung Galaxy Tab S 8.4
    Last Post: 09-02-2014, 10:23 PM
  2. Can't chmod with ES Explorer
    By barth2 in forum General Help and How To
    Last Post: 08-24-2014, 03:59 PM
  3. Replies: 3
    Last Post: 08-23-2014, 03:24 AM
  4. Voice dial doesn't work with my bluetooth
    Last Post: 08-23-2014, 02:40 AM
  5. Replies: 1
    Last Post: 08-23-2014, 02:10 AM
