1. AC Question's Avatar
    Okay so I have owned this Samsung Note 10.1 for the last year or so and I've been very satisfied.
    But for the last 6-7 days it has behaved so weird. It got its update to Android 4.4.2 Kitkat about 2 months ago and has worked fine till now.
    Since the last 6-7 days, its battery charging has been frustratingly slow, and by slow I mean it goes from 4% to 70% in a full day of continuous charging and still a long way to go for 100%. I don't understand what's wrong.
    Ever since I have owned it, it used to charge from near 0% to 100% in 55mins to 1 hour 10mins max.
    Suddenly it isn't charging the same anymore.
    If I charge it to 100% and then remove it from 100% charge, it gives me good backup. Same as its always been. Slightly better after the upgrade to Kitkat, so no complaints there.
    But then why isn't it charging at the same speed anymore? Has something changed? Please help.
    I have tried a hard reboot and tried charging on different power points at home. No joy!
    I am using the original Samsung charger unit I got with it.
    Also, I have checked that there are no background apps running at all and my usual screen brightness setting is 20% or below, which has always been the case coz I prefer to keep my devices on the lower side of the brightness levels to protect my eyes !
    So, what else could be playing the trick??
    Please help.
    08-23-2014 02:06 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It could be a problem with your charger or charging port. Charging cables can fail over time, so try a new one. If a different charger doesn't help, then you may need to bring the tablet in to a repair shop to examine the port.
    08-23-2014 02:18 PM
  1. How to cancel voice navigation by Google Now?
    By pb2222 in forum Ask a Question
    Last Post: 08-07-2016, 02:53 PM
  2. Cannot login to aptoide on archos 70
    By TheUnknownT in forum Ask a Question
    Last Post: 08-24-2014, 01:25 AM
  3. galaxy note 2 red dot
    By Rafic Beydoun in forum Ask a Question
    Last Post: 08-23-2014, 05:13 PM
  4. Galaxy Tab 3 10.1 blinking buttons then shutdown
    By Skex506 in forum Ask a Question
    Last Post: 08-23-2014, 02:55 PM
  5. Charge Asus Transformer TF701 for the first time
    By Christof477 in forum ASUS Transformer Pad TF701
    Last Post: 08-23-2014, 02:28 PM
