+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Default Samsung Galaxy S 4 and Note 8 WiFi Connection Problems
    My daughter has a Galaxy s 4 cell phone and I have a Note 8 tablet. Both work fine with our wireless router at home. Went to a hotel this weekend, both showed as connected to the hotels wifi, but both showed unstable connections, and couldn't retrieve anything from the Internet. But the wireless on my Iphone and my daughter's Ipad connected fine.
    Similar issue at my daughters college. Her Ipad connects to WiFi fine, but not her Galaxy 2.
    Any ideas?
  2. #2
    Default Re: Samsung Galaxy S 4 and Note 8 WiFi Connection Problems
    Welcome to Android Central! I assume you tried to login to the hotel's wifi on the splash screen in the browser? If you don't login there, the device will show a connection, but won't actually have internet access.
    If you did login, or if you couldn't even get to that stage, you may have had to go to Settings>Wi-fi, tap the Menu button and then Advanced, and uncheck "Avoid Weak Connections" (if that option is available).
  1. Note 4 Samsung's feel cheap & are bloated......
    By orlanka in forum Samsung Galaxy Note 4
    Last Post: 09-03-2014, 02:16 AM
  2. towel root att note 3
    By jason ring in forum Ask a Question
    Last Post: 08-24-2014, 10:24 PM
  3. Obtain data from AT&T Samsung Galaxy Note (1st Gen)
    Last Post: 08-24-2014, 10:18 PM
  4. Verizon Galaxy S5 - Anyone run into this issue? Samsung Knox Counter Went missing!
    By Djuno420 in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 08-24-2014, 09:57 PM
  5. runkeeper and gallaxy s3
    Last Post: 08-24-2014, 09:43 PM
