+ Reply
Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By belodion
  • 1 Post By slavam2605
    AC Question
    AC Question's Avatar
    Guest
    Default CM11 -- Wifi battery drain
    I have cm11 on my Live With Walkman and there is strange thing -- in 'Settings -> Battery' the most of charge was spent by Wi-Fi, but all this time Wi-Fi was turned off (but on battery plot seems like wifi was turned on, but actually not). What is going on and how I can fix it?
  2. #2
    Default Re: CM11 -- Wifi battery drain
    A Soft Reset may fix it.
    Are you set up to allow Google and some apps to use your wifi for scanning purposes? Look in your wifi settings.
    slavam2605 likes this.
  3. #3
    Thanks a lot! I forbade to enable wifi for Google services and all became good) I'm new on Android 4.*, so I did'n even new about such settings)
    srkmagnus likes this.
  4. #4
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Quote Originally Posted by slavam2605 View Post
    Good to see that you got it working. Let us know if you have further questions.
  1. Samsung Galaxy S 4 and Note 8 WiFi Connection Problems
    Last Post: 08-25-2014, 12:17 AM
  2. S3 Google Chrome app is only app thats connecting to wifi
    Last Post: 08-24-2014, 08:11 PM
  3. wifi issues
    By charlier1977 in forum AT&T Samsung Galaxy S4
    Last Post: 08-24-2014, 03:54 PM
  4. gear 2 neo battery/ charging dock not charging
    By Tyler Shaper in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 08-24-2014, 02:52 PM
  5. wifi problem
    Last Post: 08-24-2014, 11:42 AM
