Results 1 to 4 of 4
    Default battery use jellybean 4.1-2 vs kitcat 4.4.4
    Hello.
    So iv got an old samsung galaxy S2 and have read there is a posebility to load kitkat on it. But before I try that I wanted to know about batteryusage of the kitkat? Normaly battery usage and strain on a device goies up when you get tougher software.
    Also, is there a way to permanently remove all the google play and google programs on the device that uses a lot of space?
  2. #2
    VW Maverick's Avatar
    Posts
    Carrier
    Nitrogen OS 7.1.1 Nougat
    Default Re: battery use jellybean 4.1-2 vs kitcat 4.4.4
    Welcome.
    The first few days after a new Operating System is installed can make the battery use increase, but after that and a few battery charging cycles, it usually settles down.
    All of the Google stuff is pre-loaded. It cannot be un-installed.
    You can disable them, but that can cause problems elsewhere.
    Mav.
    So there is no gain in battery by changing versions? No more atleast then resetting the phone on the old 4.1.2?
    Is there any other real advantage with kitkat if im happy with 4.1.2?
  4. #4
    Posts
    Carrier
    Each update has adjusted their battery use for the better.
    KitKat is alot smoother than the previous version.
    It is, of course, all up to you on which Operating System you prefer.
    Mav.
  1. Anyone here who uses showbox...?
    By lexfrancis in forum Android Apps
    Last Post: 09-04-2014, 03:18 PM
  2. Different questions regarding use of Samsung Galaxy S3 Mini.
    By TheDustyBoy in forum Samsung Galaxy S3 Mini
    Last Post: 08-27-2014, 10:24 PM
  3. What to use to update samsung s3 instead of samsung kies?
    Last Post: 08-26-2014, 01:19 AM
  4. Google+ auto-archive option to save battery
    Last Post: 08-25-2014, 02:54 PM
  5. Replies: 0
    Last Post: 08-25-2014, 05:10 AM
