Welcome to Android Central! What happens if you press the Home or Back button? If you can get back to the homescreen, go to the App Manager, select Retail Mode, and see if you can uninstall it. If you can't, hopefully you can disable it.
It's puzzling that you'd have Retail Mode on your phone. Did you get a floor model?
