+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Unhappy Battery problems Galaxy phone
    Hi, Have had my Android Samsung G4 about 14 months, suddenly it has started to rapidly loose power, battery goes from fully charged to zero in under 10-20 minutes, anyone any suggestions as to what I might do
  2. #2
    belodion's Avatar
    Posts
    Global Posts
    19,829 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery problems Galaxy phone
    It sounds like battery failure. Try another without buying first if you can, perhaps from a friendly repairer, in case it's not that.
  1. Huge Problems After 4.4.3 AT&T Update
    By ptakistan in forum HTC One M8
    Last Post: 10-02-2014, 01:59 PM
  2. Problem installing Custom ROM. Please Help
    By SayIDidIt in forum Samsung Galaxy S3 Mini
    Last Post: 08-29-2014, 03:54 AM
  3. Boot Loop Galaxy S2: How to retrieve files before Hard Reset
    Last Post: 08-28-2014, 03:18 AM
  4. gmail autofill on Samsung Galaxy s5
    By cheller84 in forum Ask a Question
    Last Post: 08-28-2014, 02:30 AM
  5. samsung note 3 charging problem
    By Farhana1234 in forum Ask a Question
    Last Post: 08-28-2014, 02:21 AM
