+ Reply
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By belodion
  • 1 Post By oldsoldier
    AC Question
    AC Question's Avatar
    Guest
    Default Water damage to S5 help plz
    i dropped my phone in the shower and the back fell off and water got inside the phone and now its like flashing the starting up thing over and over is there anyway i can fix it?
  2. #2
    Default Re: Water damage to S5 help plz
    Turn it off and remove the battery. You may have fried the phone but you never know. Try swabbing the gold circuit parts with rubbing alcohol to remove dirt and minerals , then put in uncooked rice (bury it, phone & battery) in an airtight container for at least 3 days or more is better. Don't turn it back on yet.
  3. #3
    Default
    Rukbat, one of our members, gives expert advice:
    http://androidforums.com/faqs/815124...-try-save.html
    (Edit...posted same moment as previous post.)
    mrsmumbles likes this.
  4. #4
    Future reference-whenever you have something like this happen, do NOT turn it on.
    belodion likes this.
  1. How to keep chrome working in the background?
    By HananSabo in forum Ask a Question
    Last Post: 04-06-2015, 02:51 AM
  2. How to restore Sony Xperia V to 9.0.D.0.484 (4.0.4 ICS)
    By Promon Tester in forum Ask a Question
    Last Post: 08-29-2014, 04:00 AM
  3. Problem installing Custom ROM. Please Help
    By SayIDidIt in forum Samsung Galaxy S3 Mini
    Last Post: 08-29-2014, 03:54 AM
  4. Unable to download apps from play store
    Last Post: 08-28-2014, 11:58 PM
  5. Boot Loop Galaxy S2: How to retrieve files before Hard Reset
    Last Post: 08-28-2014, 03:18 AM
