+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Default problems with phone charging and draining fast
    I am having problems with Samsung s4 draining fast and not charging and also it's very hot!!!
    Scott
  2. #2
    SpookDroid's Avatar
    Posts
    Global Posts
    11,688 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: problems with phone charging and draining fast
    Every time something like this happens, more often than not, it's the battery. If possible, try another one (from a friend, or maybe you have an extra one?). Definitely try another one BEFORE actually buying one. Another way to tell is to check if the battery is bloated. Lay it flat on a table, and if it bobbles or can roll around (as in 'not flat at all') then it's definitely a dying battery.
    It could also be that something is creating a short circuit inside the phone (most likely the USB port or the charging circuitry).
    BOTH SITUATIONS are very dangerous to your phone and yes, call me paranoid, but even to you. Both are fire hazards if you continue to use a phone with a bad battery or faulty charging circuitry.
  1. Android wear with the note 3
    By Armthah0meless in forum AT&T Samsung Galaxy Note 3
    Last Post: 09-30-2014, 06:33 AM
  2. Battery issues with 4.4.2
    By mikeinpa in forum AT&T Galaxy S3
    Last Post: 08-29-2014, 12:39 AM
  3. Samsung Infuse i997 won't turn on and gets very hot
    By Theesire in forum AT&T Samsung Infuse
    Last Post: 08-28-2014, 09:11 PM
  4. Slow phone - One app... to close them all!
    By wenchzilla in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 08-28-2014, 10:49 AM
  5. Android wear with the note 3
    Last Post: 08-28-2014, 09:07 AM
