+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Question Help - Transferring pictures from old phone that was dropped in water
    Daughter has a Samsung Note 3 that was dropped in water. The battery doesn't work & the phone will not hold a charge with a new battery. Received new phone & need assistance with transferring pictures from the old phone (dead-won't hold charge) to the new one.
  2. #2
    SpookDroid's Avatar
    Posts
    Global Posts
    11,684 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Help - Transferring pictures from old phone
    Well, I know this is not what you want to hear, but with a dead phone, there's not much you can actually do unless you backed up your pictures on the Cloud (which I STRONGLY suggest you start doing from now on if you haven't already) or stored them on an SD Card, there is just no way to save or transfer the data without a proper repair service. And even then, if there was water damage that might have short-circuited the internal memory chip, your pictures and data might be gone (worst case scenario, but it's a possibility you should get ready for).
    For Cloud storage options, you have a bevvy of those. But since you mentioned the Note 3, that came with 50GB in Dropbox for, I believe, one or two years. You can also use Google Drive/Photos, and in this case, if you select the option to upload the pictures in Standard Size (it converts your pictures to a 3 MegaPixel equivalent, which are still pretty decent) they won't even count against your storage quota. You have Microsoft's SkyDrive or Box.
  1. Wi-fi problem - 'authentication problem' - HELP ME!
    Last Post: 08-06-2016, 12:21 AM
  2. No Vibrate from Calendar App
    Last Post: 09-20-2014, 05:56 PM
  3. Android can't handle extensions imported from Outlook
    Last Post: 08-28-2014, 11:07 AM
  4. problems with phone charging and draining fast
    Last Post: 08-28-2014, 11:05 AM
  5. Slow phone - One app... to close them all!
    By wenchzilla in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 08-28-2014, 10:49 AM
