+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Exclamation battery dies wierdly
    i have a Samsung galaxy tab 3 10.1 and when i am using it, it seems fine but when the battery is around 10 percent the screens goes off and it doesn't charge, when i put it on charge it turns on and reboots normally but its says the device is a 1 percent, what is the problem and what do i do?
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    78,110 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: battery dies wierdly
    Welcome to Android Central! I think that once the battery gets down to 10% or below, the accuracy of the reading can start to get erratic. I generally don't let my devices get far below 20%.
  1. Solved my battery drop & heat issue
    By Kwjmac in forum LG G3
    Last Post: 03-31-2015, 03:35 PM
  2. Should I be worried about my Nexus 5 battery?
    By salmanahmad in forum Google Nexus 5
    Last Post: 09-26-2014, 01:38 PM
  3. How to get the rumored 20+ Hour battery life?
    By moviedude2k in forum Moto X (2013)
    Last Post: 09-05-2014, 10:45 PM
  4. Potential Lag, Camera Lag, and battery fix
    By TNCattleDog in forum LG G2
    Last Post: 09-02-2014, 06:32 PM
  5. Extended Life Battery
    By Murph5150 in forum LG G3
    Last Post: 08-28-2014, 10:14 PM
