1. AC Question's Avatar
    galaxy s3500 suddenly turns off and wont turn what do i do>?
    08-29-2014 05:32 AM
  2. belodion's Avatar
    The first thing to do is to test for battery failure. Try another if you can, but without buying, in case it is not the battery.
    08-29-2014 05:53 AM
  3. ukbuk's Avatar
    Also, check the contacts with the battery. If they don't fit snug on to it then the battery could come away from the contacts and effectively switch the phone off.
    Cheers
    Nick
    08-29-2014 06:07 AM
  1. Is my HTC M8 dead after some water damage?
    By snorrow in forum HTC One M8
    Last Post: 07-02-2015, 06:43 PM
  2. phone not working
    Last Post: 08-29-2014, 06:07 AM
  3. how to reduce android phones battery waste
    By effimote in forum Ask a Question
    Last Post: 08-29-2014, 05:11 AM
  4. Replies: 1
    Last Post: 08-29-2014, 01:48 AM
  5. Replies: 1
    Last Post: 08-29-2014, 01:14 AM
