+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Default S5 low battery
    Is there some easy way to put the S5 back to previous settings after it has gone into power saving mode? I find that when the battery gets below a certain % it set my ringtone volume on low, stops Gmail sync, dims the display, switches off WiFi, switches off message alerts and a bunch of other things. It's a pain having to remember to go back and re-set everything whenever the battery gets low. BTW I'm not talking about Ultra Power Saving Mode, just regular low battery.
  2. #2
    Default Re: S5 low battery
    Hello. I have a Note 3. If you press Power Saving Mode in the General settings (not the switch on the Notification shade), do you have more options there?
    Sent from my SM-N9005 using Tapatalk Pro
  1. How make S5 NOT show my number on calls......
    By dkperez in forum Samsung Galaxy S5
    Last Post: 09-08-2015, 10:28 AM
  2. samsung s5 keyboard has stopped working
    Last Post: 09-01-2015, 01:03 PM
  3. You can wash your S5 in your washing machine!
    By Drummerboy1975 in forum Samsung Galaxy S5
    Last Post: 05-30-2015, 09:57 AM
  4. OS using over 80%, new battery draining fast.
    By Mariah Anger in forum Verizon Galaxy S3
    Last Post: 09-11-2014, 12:41 PM
  5. lg g3 battery saver mode
    By Unregistered in forum Ask a Question
    Last Post: 08-29-2014, 10:22 PM
