1. AC Question's Avatar
    Hello,
    I just got this phone about a week ago and now I've been having batter issues at night. For instance, I asked someone and they said to turn off auto updates because that might be the problem so I did and last night when I went to bed, it was at 72% and the about 5 am, I got woken up by the lovely sound of the low battery alert so something is wrong. I did notice my stats say Android OS at 41% and Android System at 14%and Google Play at 14%. Any thoughts before I dump this phone? I got it so I wouldn't be tethered to a cord all the time.
    08-31-2014 08:00 AM
  2. belodion's Avatar
    A Soft Reset may cure the problem temporarily.
    Is your location reporting set to GPS? Battery Saving mode will help.
    A third-party app may be draining the battery in the background....if you can think of a likely culprit, try uninstalling it. Safe Mode may be worth considering if you can't think of an obvious culprit:
    http://support.t-mobile.com/docs/DOC-10696
    08-31-2014 08:28 AM
  1. Galaxy S5 dual sim (duos)
    By Bacchus17 in forum Ask a Question
    Last Post: 10-28-2014, 04:42 PM
  2. note 3 battery w pics
    By marselisgn3 in forum Samsung Galaxy Note 3
    Last Post: 09-03-2014, 05:18 AM
  3. Galaxy S3 wii password problem
    Last Post: 08-31-2014, 07:22 PM
  4. Problem accesing all my google APS on Salaxsy S5
    By mornstein in forum Samsung Galaxy S5
    Last Post: 08-31-2014, 12:41 PM
  5. Galaxy Note 3 Keeps sending SMS infinitely !
    Last Post: 08-31-2014, 07:51 AM
