Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By jenjr1943
    Default Verizon's HTC Incredible 4G LTE WiFi Problem
    My phone is Verizon's HTC Incredible 4G LTE. When I have Wifi enabled, and connect to it (such as at my home), then go out of range, my phone does not automatically switch to using data. It stays stuck on Wifi (it says it is connected to my home network even when I am 30 miles away at work) until I disable Wifi. After I disable Wifi, the phone will switch to data, and I can enable Wifi again and the phone will continue to use data. This is annoying because I don't get notifications unless I remember to toggle the Wifi, every single time I leave my house. Anyone having this issue? Any solutions?
  2. #2
    Default Re: Verizon's HTC Incredible 4G LTE WiFi Problem
    Welcome to Android Central! That's odd. Go to Settings>Wi-fi, tap the Menu button, and then Advanced, and see what settings are there. If there's something like "Avoid weak signals," check that on to see if it helps.
    No category like that on my phone.
  4. #4
    What options are there in the Advanced Wi-Fi settings?
    If you can't find anything there that helps, you may want to consider a factory data reset. Of course, that will wipe the phone, so you'd have to backup your data first.
    Notify me, Keep wifi on during sleep, wifi frequency band, best wifi performance, never auto turn on wifi, mac address, ip address, DLNA auto-IP
  6. #6
    Uncheck "Best Wi-fi Performance" and "Never Auto Turn On Wi-fi," if they're already checked, and see if that helps.
    I unchecked "Best Wi-Fi Performance" and that solved the problem. Thanks for your help.
    B. Diddy likes this.
  1. Galaxy S5 saves unsecured WIFI connection
    Last Post: 10-16-2014, 05:45 PM
  2. Accuweather widget problem
    By marios1441 in forum General News & Discussion
    Last Post: 09-01-2014, 11:38 AM
  3. problem with google play store
    Last Post: 09-01-2014, 10:46 AM
  4. Deleted bloatware back after reboot HTC One M7
    By AntonBu in forum Ask a Question
    Last Post: 09-01-2014, 08:29 AM
  5. Htc desire 601
    Last Post: 09-01-2014, 07:09 AM
