+ Reply
Results 1 to 3 of 3
    AC Question
    AC Question's Avatar
    Guest
    Default Sasmsung glaxy s5 SD card problem.
    Hello when i install the mini sd 32gb into the s5, trying to record video and take picture when it save into the sd card, The file corrupted, anyone know what is the issues Thanks. When i remove the SD card it work fine.
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,771 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Sasmsung glaxy s5 SD card problem.
    Quote Originally Posted by AC Question View Post
    What kind of SD Card are you using? Also, does it work fine on other devices? I'm thinking it's an issue with the SD Card, and it may have problems being read by the S5.
  3. #3
    Monkey1oo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the HC sd card 32gb. Should i try reformat
    it?
  1. S5 Lock Screen time out
    By BettysNephew in forum Samsung Galaxy S5
    Last Post: 02-24-2015, 07:17 AM
  2. SD Card Picture Uploads????
    By BenJammin88 in forum Ask a Question
    Last Post: 09-01-2014, 11:35 PM
  3. ads keep popping up, almost unable to use my S5 anymore
    Last Post: 09-01-2014, 11:22 PM
  4. wifi problem with HTC one E8
    Last Post: 09-01-2014, 11:04 PM
  5. Samsung Galaxy S5 Electric Blue
    Last Post: 09-01-2014, 11:01 PM
