Results 1 to 4 of 4
    the1hooper's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Verizon samsung galaxy note 3 battery dying rapidly
    Recently my note 3 has been losing battery quickly. I havent had the phone a month yet, and the battery loses 15% in a hour. I know that is not normal at all. It recently has said that Instagram uses anywhere between 40-55% of my battery, yet I close it everytime Im done with it. I uninstalled IG, same issue. I did a factory reset, same issue. Any suggestions on how to fix this..??
  2. #2
    belodion's Avatar
    Posts
    Global Posts
    19,882 Global Posts
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Default
    Welcome to the Forums!
    You could try entering Safe Mode which temporarily disables third-party apps, and allows you to identify any battery-guzzling culprits.
    If you do have an app or apps eating battery, there should be some clue in your battery usage stats. Anything unusual there?
    It's also possible that, though nearly new, the battery is failing, so don't discount that outright.
    the1hooper's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Verizon samsung galaxy note 3 battery dying rapidly
    I called verizon and they ordered me a new battery. Im going to see if that helps. When I go into battery stats, it says instagram using about 45% of my battery, ( or it says com.android.instagram -some message ike that any idea?
  4. #4
    belodion's Avatar
    Posts
    Global Posts
    19,882 Global Posts
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Default
    Take a look at this:
    http://forum.xda-developers.com/show....php?t=1838667
  1. Galaxy S4 Mini - Palm Motion Capture Screen Setting missing
    Last Post: 05-03-2015, 05:08 AM
  2. Samsung Galaxy S5
    Last Post: 04-21-2015, 05:23 PM
  3. galaxy tab 3 "no vpn" message when try to set up vpn
    By Unregistered in forum Ask a Question
    Last Post: 09-05-2014, 10:43 AM
  4. Samsung Galaxy S2 GT-i9100 related questions
    By aliatif91 in forum Ask a Question
    Last Post: 09-02-2014, 07:21 PM
  5. Samsung galaxy s4 mini phone and deleted bookmarks!
    Last Post: 09-02-2014, 01:58 PM
