1. AC Question's Avatar
    Normally I get 2 days on the battery with modest use. Over the weekend I was out of 4G often and sometimes out of range altogether. Still, the battery was at 35-40% by the end of the evening.
    Today, after 8 hours on WiFi it was down to 34%; down to 3% after 15 hours. I checked the battery log and it says 47% of my usage is for something called "Help". How could a "Help" app suddenly cause my battery to drain and how can I correct that?? I did "force stop" the app but it seems to restart itself (as it probably should).
    09-02-2014 11:10 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does it persist after a reboot? It might have been a temporary app glitch. If it recurs, do this:
    Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    How to post screenshots: http://forums.androidcentral.com/amb...d-central.html
    09-03-2014 12:45 AM
  1. We need an extended life battery.
    By Murph5150 in forum LG G3
    Last Post: 09-03-2014, 10:13 PM
  2. Samsung S4 Battery drains when on charger
    By Delia Brennan in forum Samsung Galaxy S4
    Last Post: 09-03-2014, 09:45 AM
  3. Replies: 1
    Last Post: 09-02-2014, 11:19 PM
  4. Replies: 0
    Last Post: 09-02-2014, 10:49 PM
  5. Battery friendly Music App
    By TomW093 in forum Android Apps
    Last Post: 09-02-2014, 10:11 PM
