1. AC Question's Avatar
    My S5 connects to my wireless hub just fine. But once it connects it slows our DSL down to a crawl. We just upgraded and got three S5s and they all three to the same thing. How do I fix this problem. Our old Samsungs did not do this. Help!!!
    09-03-2014 02:25 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you know if your router has any QoS (Quality of Service) settings turned on? This setting can be used to prioritize certain connections over others (like, for example, if you want to make sure a streaming video on your smart TV doesn't get choppy, it get's the top QoS, while other devices that don't need as fast a connection get bumped down to a lower QoS.
    You'd have to log into the router using your computer's browser. Check your router's manual for instructions on how to do so.
    09-03-2014 05:46 PM
  3. Mwettig's Avatar
    I have not had any problem for 3 years until we got these phones.
    09-03-2014 06:37 PM
  4. B. Diddy's Avatar
    That's pretty weird. Try rebooting the router, or temporarily turning off the router security. Review this guide for more info: http://forums.androidcentral.com/amb...-problems.html
    09-03-2014 07:07 PM
  5. Mwettig's Avatar
    I tried rebooting. I changed setting on phone. I removed connection and redid it. The WIFI works great on the phone once connected. It just will not allow anything else to work in our home network. Slow the DSL down to a crawl. WIFI runs 100 MPH while is connected.
    09-03-2014 07:13 PM
  6. Diana Carr1's Avatar
    Did you ever figure this out? I just got the s5 about a month ago and everytime I turn on Wifi in my house, the whole internet connection slows down and I cannot connect with any other device.
    07-19-2015 04:24 PM
  7. Mwettig's Avatar
    Yes I did. The phone was taking updates to several programs. Let it run over night and all should be good.
    07-19-2015 05:00 PM
  1. Battery problems
    By Nicolas Whipp in forum Samsung Galaxy S4
    Last Post: 09-05-2014, 04:25 AM
  2. Htc one mini 2 speaker problem
    Last Post: 09-03-2014, 05:53 PM
  3. Samsung Tablet - Wifi connection
    Last Post: 09-03-2014, 05:52 PM
  4. Samsung Galaxy S4 root problem, Need help :(
    Last Post: 09-03-2014, 03:09 AM
  5. [ROOT] HTC One Mini 601e Root Problems
    By Yirga in forum Ask a Question
    Last Post: 09-03-2014, 01:22 AM
