1. AC Question's Avatar
    My handset is around a year old. Battery life has always been reasonable for a smartphone, I am not a heavy user of apps etc, but a few weeks ago suddenly started draining ridiculously fast (goes from 100% to 75% in 2 hours with no use of phone). I bought a new battery but no improvement. Turning off WiFi/GPS/data etc does not seem to make any difference. Any tips, is there a particular update to blame for this?
    09-04-2014 08:18 AM
  2. belodion's Avatar
    What do your battery usage stats indicate as the chief users of battery charge?
    Safe Mode will temporarily disable any third party apps you may have downloaded and allow you to identify ones that may be draining the battery.
    09-04-2014 12:15 PM
  1. Replies: 3
    Last Post: 09-05-2014, 10:57 AM
  2. Replies: 1
    Last Post: 09-04-2014, 02:56 PM
  3. Replies: 0
    Last Post: 09-04-2014, 06:39 AM
  4. Replies: 0
    Last Post: 09-04-2014, 06:36 AM
  5. Replies: 1
    Last Post: 09-04-2014, 05:40 AM
