1. predators_blade's Avatar
    Hi ,
    Hope can someone help me out with the i bought an HTC one X + 4 months back and the phone started heating when i use WIFI or 3G , it was all fine from the beginning , but it recently started heating upto temps of 45-50'C is there any fix for this kindly help , would really appreciate if someone can get me out of this heating issue.
    09-06-2014 07:13 AM
  2. mrsmumbles's Avatar
    Are you playing a game, or doing a lot when it gets too hot?
    09-06-2014 07:28 AM
  3. belodion's Avatar
    Welcome to the Forums!
    The first thing to check, because it's a possible cause of overheating, is the battery. It could be failing....if the back is removable, take the battery out and see whether it seems to be bulging. If so, it will need replacing....but even if not, it could still be failing.
    There are other possible causes of overheating so get back to us if necessary.
    Edit. Posted same time as preceding post....Yes, what mrsmumbles says is one of the other causes.
    mrsmumbles likes this.
    09-06-2014 07:30 AM
  1. touchwiz home keeps popping up everytime I hit the home button
    By Michelle Power1 in forum Ask a Question
    Last Post: 09-07-2014, 12:01 PM
  2. htc one max
    Last Post: 09-06-2014, 01:09 PM
  3. Galaxy S5 Overheating
    By Mohis in forum Samsung Galaxy S5
    Last Post: 09-06-2014, 09:14 AM
  4. samsung 3 8 inch tab battery drain
    By Richard Porter2 in forum Ask a Question
    Last Post: 09-06-2014, 07:34 AM
  5. Battery type tablet device taj shuraim
    Last Post: 09-06-2014, 03:35 AM
