1. AC Question's Avatar
    i purchase samsung galaxy grand 2 mobile date 28 may 2014.but my mobile hang and restart 6 to 7 time in the day.so ply give me my mobile problem solution.
    09-06-2014 09:08 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Recovery and wiping the cache partition, which won't erase any personal data. Follow the steps in this video, but instead of selecting Wipe Data/Factory Reset, make sure you select Wipe Cache Partition. When that's done, select Reboot System Now.
    If that doesn't help, try unmounting the SD card (in Settings>Storage), removing it, and rebooting. A corrupt card can cause problems.
    09-06-2014 12:57 PM
  1. Replies: 2
    Last Post: 09-17-2014, 07:16 AM
  2. Samsung s4 battery draining a little fast for me
    By Sammy Diab in forum Samsung Galaxy S4
    Last Post: 09-11-2014, 01:15 AM
  3. Replies: 1
    Last Post: 09-06-2014, 03:35 PM
  4. Cant recognize sd card 8gb in samsung s5830
    Last Post: 09-06-2014, 09:09 AM
  5. samsung 3 8 inch tab battery drain
    By Richard Porter2 in forum Ask a Question
    Last Post: 09-06-2014, 07:34 AM
