1. AC Question's Avatar
    I recently purchased an F33 Sports DVR camcorder to work with my ZTE Majesty's WiFi. It's running Android 4.1.2 , up to date & functioning fine. The F33 requires an app called WiFi SmartCam to connect using WiFi, but the app cannot detect the camcorder. Anybody else run into this problem? Since the app cannot detect the camcorder wirelessly, I also cannot select the 'setup' button to manually enter in the model info. Very frustrating.
    Any help would be greatly appreciated.
    Randall
    09-06-2014 08:08 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I'm not sure how a camcorder would connect and communicate via wi-fi with your phone. If you used your phone as a wi-fi hotspot, then you could conceivably connect your camcorder to the internet by using the phone's hotspot--but it won't communicate with the phone this way. That's what Bluetooth is for. Are you sure it isn't a Bluetooth connection?
    Is this "Wifi SmartCam" program an actual Android app, or a program for your Windows or Mac computer?
    09-06-2014 08:39 PM
  1. Replies: 2
    Last Post: 09-06-2014, 09:34 PM
  2. Help with wireless chargers
    By androiduser24645 in forum Ask a Question
    Last Post: 09-06-2014, 09:12 PM
  3. Replies: 0
    Last Post: 09-06-2014, 05:00 PM
  4. Need Help for Go Launcher
    By losl in forum Google Nexus 5
    Last Post: 09-06-2014, 04:34 PM
  5. Problem with Dropbox on Samsung 10.1. videos showing as empty
    By Willow33 in forum Samsung Galaxy Note 10.1
    Last Post: 09-06-2014, 04:25 PM
