1. Unregistered's Avatar
    I was on youtube and my audio just stopped working and now I can't hear found for anything. Please help!!!!
    09-06-2014 11:07 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you mean that you have a Samsung Galaxy Centura? Have you tried rebooting the phone?
    09-06-2014 11:20 PM
  3. drago2drago's Avatar
    Yes it is the centuria And I saw I had the option for a factory restore but m worried I will lose the value of my time card
    09-06-2014 11:38 PM
  4. B. Diddy's Avatar
    Time card? You mean your SD card or your SIM card?
    I was just suggesting a reboot, not a factory reset. Just power the phone down by pressing and holding the Power button until you see the Power options, then tap Power Off. For good measure, once it's off, remove the battery and wait 10 seconds. Then put the battery back in, and turn the phone back on. Is the audio still messed up?
    09-07-2014 12:25 AM
  5. drago2drago's Avatar
    I did the reboot and it didn't work and by time card I mean the hard you buy with tracphones To get service
    09-07-2014 09:18 AM
  1. Replies: 1
    Last Post: 09-07-2014, 12:25 AM
  2. recorded video with audio timing off
    By Redrose in forum Ask a Question
    Last Post: 09-06-2014, 10:24 PM
  3. Help with ZTE Majesty WiFi & F33 Sports DVR
    Last Post: 09-06-2014, 08:39 PM
  4. Replies: 0
    Last Post: 09-06-2014, 05:00 PM
  5. Need Help for Go Launcher
    By losl in forum Google Nexus 5
    Last Post: 09-06-2014, 04:34 PM
