A AC Question Sep 7, 2014 #1 It won't connect. The only reason I can think of for the problem is wiping the cache partition. Any fix?
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,536 4,674 113 Visit site Sep 7, 2014 #2 What happens when you try to connect? Review this guide and see if the tips help: http://forums.androidcentral.com/am...roubleshooting-wi-fi-connection-problems.html Upvote 0 Downvote
H hannabbbanana New member Sep 7, 2014 1 0 0 Visit site Sep 7, 2014 #3 it just says saved,secured. I triedeverything on the list it still doesn't work Upvote 0 Downvote
