1. Ronaldo Rond's Avatar
    I am having wifi connection problem . My GS5 keep disconnecting from wifi every 3 - 5 minutes then it'll connected again .
    Changed the wifi settings to static , turn off power saver wifi . Tried all that but nothing helps.
    Tried factory reset . And it fixed the problem . But the problem appeared again in 4 - 5 days after i did the factory reset.
    So i don't think its my radio problem .
    And also other devices such as laptop , ipod , ipad works fine with my router so i dont think its my router problem.
    Maybe software ? But idk . i'm not really good at something like this
    Anyone else having this problem ? This is really frustrating .
    I don't want to keep resetting my phone just for this because i'll lose all of my apps .
    Please Help
    Thanks
    Sorry for bad english
    09-07-2014 10:56 AM
  2. belodion's Avatar
    Welcome to the Forums.
    In Settings, Wifi, menu, Advanced Wifi, is the phone set to automatically disconnect if wifi signal is weak? If so, that may be the problem.
    (And by the way, your English is good.)
    09-07-2014 12:22 PM
  3. Ronaldo Rond's Avatar
    Thanks for your response . I think its not the problem because it is also happened when i'm close to the router.
    Did a factory reset yesterday because i really need the wifi .
    But unfortunately , the factory reset is only for a temporary fix.
    I resetted this phone 3 times . Just because of the wifi .
    09-08-2014 10:07 AM
  1. Micro SD problem
    By Danyyyy00 in forum Ask a Question
    Last Post: 09-08-2014, 04:36 PM
  2. Replies: 6
    Last Post: 09-08-2014, 10:54 AM
  3. can't upgrade to kitkat on galaxy s3 I747 by AT&T
    By danielthesea in forum Ask a Question
    Last Post: 09-07-2014, 11:59 PM
  4. Can't connect Samsung Galaxy S2 to PC
    Last Post: 09-07-2014, 11:00 AM
  5. How do I get my Samsung Galaxy SII out of bootloop?
    By AC Question in forum Samsung Galaxy S2
    Last Post: 09-07-2014, 09:07 AM
