1. Desarrowan's Avatar
    My Micro SD card wont mount on phone or Pc. I plugged it in my pc with adapter and installed drivers. I go to Device manager and says error 10 on the sd card. I need help pls. My phones wont detect it.
    09-09-2014 04:07 PM
  2. Golfdriver97's Avatar
    The card may have failed. If the PC can't read it, it is probably gone.
    09-09-2014 04:27 PM
  3. Elizabeth Sherry's Avatar
    WHAT would cause the card to fail? IS there no work around . . . software like Recuva or something like that?
    09-09-2014 08:16 PM
  4. Golfdriver97's Avatar
    Bad card if it's new. Age, any type of damage, like overheating, etc...
    You can try recovering the card, but in my experience, once a card is starting to fail, even if you fix it, the question is not if but when it will fail completely.
    09-09-2014 10:26 PM
  1. Replies: 3
    Last Post: 09-10-2014, 10:23 AM
  2. Micro SD Card Mounting Error
    Last Post: 09-09-2014, 04:27 PM
  3. several problems with my htc one
    By SeekerStriker in forum HTC One Google Edition
    Last Post: 09-09-2014, 03:08 PM
  4. Problem with S5 case, phone or back cover
    By sunilbhat in forum Samsung Galaxy S5
    Last Post: 09-09-2014, 02:39 PM
  5. looking for micro sd advice
    By codeyumi in forum Ask a Question
    Last Post: 09-09-2014, 01:57 PM
