1. a-dogg's Avatar
    Hi, Android Central!
    I want to buy an unlocked ZTE nubia Z7 max. I've been googling, but apparently my google-fu...well...blows. Because I'm having an impossible time figuring out if it will work a) on T-Mobile and b) on T-Mobile LTE.
    This is from the Amazon listing:
    Network:
    Network type: TD-LTE & FDD-LTE & WCDMA & CDMA& TD-SCDMA & GSM Network
    4G: FDD-LTE 1800/2100/2600MHz
    4G: TD-LTE B38/39/40/41
    3G: CDMA EVDO 800
    3G: WCDMA 850/1900/2100 MHz
    2G: GSM 850/900/1800/1900MHz
    There's also the Z7 mini, with these specs:
    Network:
    1) Network type: FDD-LTE & WCDMA & CDMA& TD-SCDMA & GSM Network
    2) Band:
    - Band (4G): 4G: FDD-LTE B1/B3/B7
    - Band (4G): 4G: TD-LTE B38/39/40
    - Band (3G): CDMA 1X/EVDO 800
    - Band (3G): WCDMA 850/900/1900/2100 MHz
    - Band (2G): GSM 850/900/1800/1900MHz
    Any help would be hugely appreciated!
    09-09-2014 08:55 PM
  2. a-dogg's Avatar
    Did some more digging... Looks like it won't support LTE in the U.S.
    But it supports WCDMA (UMTS) bands 850/1900/2100. T-mobile uses 1900 (and 1700/2100), so it should support HSPA and HSPA+.
    09-10-2014 12:45 AM
  1. is my M8 bigger than the usual size ?
    By Aimar_69 in forum HTC One M8
    Last Post: 09-16-2014, 04:23 PM
  2. How much will the edge be for retail?
    By icellphones32 in forum Samsung Galaxy Note Edge
    Last Post: 09-14-2014, 11:55 PM
  3. iPhone 6 plus is bigger than the Note 3
    By emad1995 in forum Samsung Galaxy Note 3
    Last Post: 09-12-2014, 01:49 PM
  4. Replies: 12
    Last Post: 09-12-2014, 01:14 PM
  5. Nova Off-Camera Flash for iPhone Works GREAT with the Galaxy S5!!
    By Three7s in forum Samsung Galaxy S5 Accessories
    Last Post: 09-09-2014, 08:05 PM
