1. AC Question's Avatar
    Hello,
    I am having a problem with my new phone. I am trying to install the settings for Data connection (Mobile Internet), but everytime I do that, it asks me "Please input PIN". I have tried to introduce my phone PIN, I have tried the 1234 general code, 0000, 0808, but no luck. The phone is new, never placed a PIN for that. Is it possible to have a personal PIN, the phone itself? What should I do?
    Thanks for your time,
    Amy
    belodion likes this.
    09-10-2014 05:54 PM
  2. belodion's Avatar
    The first two numbers you tried were good guesses. I think you'll have to contact your network provider for the PIN, although it may be worth checking their website first to see whether it's mentioned there.
    (I accidentally gave you that heart symbol...it was unintentional, although of course, I wish you well.☺)
    09-10-2014 06:08 PM
  3. jezza_03's Avatar
    i cant save my configuration setting to save my data connection because needs pin.what pin should i put to save?thanks
    03-27-2016 04:31 PM
  1. Replies: 5
    Last Post: 09-11-2014, 11:07 PM
  2. Unroot Android Galaxy S4 4.2.2
    Last Post: 09-10-2014, 09:42 PM
  3. Can't connect to tv
    By pb_beaker in forum Samsung Galaxy Tab4 7.0
    Last Post: 09-10-2014, 07:51 PM
  4. s5 eats data
    Last Post: 09-10-2014, 04:47 PM
  5. T-Mobile OTA Update for S5
    Last Post: 09-10-2014, 04:41 PM
