1. kakamai's Avatar
    Folks,
    Its hardly been a month since I bought my S4 mini and the problem with the sound and headphone has started. The headphone sign refuses to go even when the haead phone is not connected. worse, I cant' connect the headphone with/into the Handset. the pin doesn't fit in at all. Have tried everything, incuding factory reset, restart etc. do I change the handset itself?
    SOS. thanks. Cheers!!!
    09-11-2014 02:15 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! If you can't fit a headphone plug in, then something is probably lodged in there. If it's metal, then it's probably making the phone think a headphone is connected. Sometimes, the tip of a headphone plug can break off in the jack and do this.
    Shine a light into the jack--do you see anything in there? If so, try this technique to get it out:
    09-11-2014 10:31 PM
  1. Any way to keep the second hand on?
    By U4icLab in forum Moto 360
    Last Post: 12-21-2014, 11:38 PM
  2. Petition to bring Moto X to t-mobile
    By cellomj in forum T-Mobile
    Last Post: 10-04-2014, 03:44 PM
  3. phone wont charge nor connect.
    Last Post: 09-11-2014, 10:28 PM
  4. How to sync dropbox. Galaxy S4
    Last Post: 09-11-2014, 04:18 PM
