A
AC Question
Hi. I have a china made mobile (branded FAEA) running android 4.4.2 and I have a problem with it since day 1. When the battery is at around 30% it just goes off, also sometimes it restarts alone. I tried three batteries but the problem is still. I contacted the site from where I bought it and first thing they suggested is a factory reset. Do you think that this might solve the problem? It's no point doing reset and losing everything if its sure nothing will change.
Thanks
Thanks
