1. AC Question's Avatar
    how do you do it?
    09-11-2014 11:05 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! You need an OTG (On-The-Go) cable, which plugs into the tablet's microUSB port, and then you plug the USB drive into the OTG cable. According to this amusingly titled review, it apparently works on this tablet: An Angry German Reviews the RCA Pro 10 Series Android Tablet | pfautsch.com
    09-12-2014 01:05 AM
  1. HTC one m7 USB error
    Last Post: 09-12-2014, 01:10 AM
  2. Replies: 11
    Last Post: 09-11-2014, 02:54 PM
  3. htc one m8: texts volume whule using earphones
    By Unregistered in forum Ask a Question
    Last Post: 09-11-2014, 11:03 AM
  4. the ability for applications to write to external SD cards...
    Last Post: 09-11-2014, 04:57 AM
  5. Replies: 1
    Last Post: 09-10-2014, 10:10 PM
