1. AC Question's Avatar
    Yesterday I brought Samsung galaxy S5 korea made. due to network problem I made Factory Reset. But now its now showing any range bar and showing that only emergency calls allowded. Friends Please help me to out from this.
    09-12-2014 05:50 AM
  2. Anastas Tomas's Avatar
    Hallo!
    I have the same problem. How do you fixed it?
    Thanks.
    07-16-2015 07:12 AM
  3. Muzike Simbeleko's Avatar
    hi, i hard the same problem but i resolved it. check the imei number by dialing *#06# i gues it will say invalid imei number. Just open your back cover remove the battery you will find it. then take to technicians they can put it or search on google there is an app used to replace back the imei number. thats all good luck.
    02-12-2016 01:50 PM
  1. Samsung Galaxy Nexus No Data
    By stretch4eva in forum Ask a Question
    Last Post: 09-22-2014, 01:58 AM
  2. Samsung galaxy s4 knox problem
    By Unregistered in forum Ask a Question
    Last Post: 09-19-2014, 06:18 PM
  3. earphones does not work..samsung galaxy s4
    By Srinivasdeva22 in forum Ask a Question
    Last Post: 09-13-2014, 12:49 AM
  4. Cant get files from Samsung Galaxy S2
    Last Post: 09-12-2014, 05:46 AM
  5. Samsung camera-gmail
    Last Post: 09-12-2014, 02:57 AM
