1. gina mcsurdy's Avatar
    My samsung galaxy 3 gets hot to touch and will not charge correctly. How do you aor I fix this?
    09-12-2014 11:05 AM
  2. jmagid51's Avatar
    Sounds like you may need a new battery. If the phone is still under warranty it may be best to return it.
    09-12-2014 11:30 AM
  3. anon8380037's Avatar
    Also try installing the GSam battery app and see what it shows. Or look at the Battery screens and see if Android OS or another app is running too much.
    Also turn off Master Sync, and Google+ and uncheck sync settings in Accounts - Google - your account, and see if that helps in the short term.
    Sent from my XT1039 using Tapatalk
    jmagid51 likes this.
    09-12-2014 12:21 PM
  1. Samsung S5 network problem for korea made
    Last Post: 02-12-2016, 01:50 PM
  2. Samsung galaxy s4 knox problem
    By Unregistered in forum Ask a Question
    Last Post: 09-19-2014, 06:18 PM
  3. Android (Motorola Photon Q) SD Card Problems
    Last Post: 09-19-2014, 08:07 AM
  4. S5 Chrome text memory problem
    By bh206206 in forum Samsung Galaxy S5
    Last Post: 09-11-2014, 10:09 PM
  5. google play store connection problems
    By Little Un in forum Ask a Question
    Last Post: 09-11-2014, 10:05 PM
