1. nonalis's Avatar
    I'm vision impaired & desperately in need of "Big Button" key board, I downloaded the free version to try & absolutely love it, so I decided to upgrade & buy the full function deluxe version, for the life of me I tried every trick in the book to download it BUT IT KEEPS GIVING ME ERROR 24, I don't want to uninstall the free version for fear I wont be able to reinstall it. any gurus out there that can help?? Thanks!!!
    09-12-2014 06:50 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If you uninstall the free version, you will always be able to reinstall it. In regards to your purchased app, try going to System Settings>Apps>All, select Google Play Store, and tap Clear Cache and Clear Data, then Force Stop. Do the same for Download Manager. Now open Google Play Store again, and try to install the paid keyboard. Don't worry--your record of the purchase should be stored in the cloud.
    09-12-2014 10:14 PM
  1. Freeze/Reboot Issue. Need you advice.
    By jjsaw5 in forum Samsung Galaxy S5
    Last Post: 03-26-2015, 12:03 PM
  2. Newbie here. I need some help please?
    By mimixiv in forum LG Optimus L
    Last Post: 09-12-2014, 10:20 PM
  3. Help
    Last Post: 09-12-2014, 03:59 PM
  4. Can anyone help with Samsung GTS-6012 rooting?
    Last Post: 09-12-2014, 11:10 AM
  5. SHV-E250L Korean Phone. Rooting Help.
    By Deathcommand in forum Samsung Galaxy Note 2 Rooting, ROMs, and Hacks
    Last Post: 09-11-2014, 10:14 PM
