A
AC Question
I've had my Galaxy S3 from Bell for about a year and a half. I didn't have issues with it for a long time until about four months ago, when I started losing battery life. I figured it was just normal wear on the battery until probably two months ago when it started doing the following:
When starting at fully charged, if I'm using it at ALL the battery will drop to anywhere from 60-30% within a few minutes before the screen starts flickering and it dies. No matter what it was at before it died, if I try turning it back on, it will show it as under 15%, frequently 1% or 0%, and immediately die again (if it even gets beyond the Samsung screen).
If I don't use it, just let it sit (as I've been trying to do in hopes it will actually stay alive in case I, you know, need a phone) it will drop more slowly and will sometimes last an hour or two... if I don't touch it. It will still drop to around 60-50% and if I try to use it- screen starts flickering, and it dies. Same as above.
I haven't replaced anything on the phone and I'm still using the exact same chargers I always have (the one that came with it, and a car charger). Haven't been able to get it checked out yet as I got screwed for hours at work over the summer, but now that I'm back in school with a little bit of leeway in terms of funds I'd like to deal with it. I'm just curious to know if there's anything I can do before getting it replaced through Bell.
Thanks for any help!
