1. Rasmus Mose's Avatar
    After letting the device completely drain the battery and turn-off by itself, I've experienced charging problems. When the phone is connected to the charger the tiny LED won't turn on (not even flashing) and the phone seems completely dead.
    After reading through several threads and trying all the following, I still didn't have any succes.
    - leave it with a wall mounted charger for 24 h
    - charge it via the computer
    - power on by using various combinations of volume buttons and the power button
    - shining bright light on the device, while trying to power on
    I found the solution to be to put it in the freezer for 5 minutes (I kidd you not!), and then connecting it to a wall mounted charger immediately after. After the phone had returned to room temperature, the LED started flashing and then after a while to the normal LED charge light. I've had this problem twice, and both times the trick with the freezer worked like a charm.
    If you try this out, don't leave it in the freezer for more than 5 minutes, as this might damage the display (leading to bright and darker spots).
    Good luck to all of you
    09-13-2014 09:10 AM
  2. Golfdriver97's Avatar
    I have heard of this once before. Thanks for posting the solution. See you around the forums.
    09-13-2014 09:25 AM
  1. galaxy note 3 not charging but showing charging symbol
    Last Post: 10-26-2014, 10:20 PM
  2. HTC ONE (M7) not finding 5ghz wifi
    By Sheikh Haroon Akram in forum HTC One M7
    Last Post: 09-15-2014, 08:43 AM
  3. Is one a fake?
    By TwigsandPebbles in forum Ask a Question
    Last Post: 09-13-2014, 06:07 PM
  4. HTC Wildfire S not showing screen
    Last Post: 09-13-2014, 05:07 PM
  5. does sun over drains battery
    By bbmjack in forum Samsung Galaxy S5
    Last Post: 09-13-2014, 08:05 AM
