1. ahooper239's Avatar
    New Android user here. I just got a new Galaxy S5 3 days ago and I've been seeing some really extreme battery drains. Yesterday I downloaded the GSam Battery Monitor and took a few screenshots this morning of the battery status. Can anyone help me find out why is draining so fast?
    Attached Thumbnails Battery drain over 20%/hr-screenshot_2014-09-13-09-21-09.jpg   Battery drain over 20%/hr-screenshot_2014-09-13-09-20-59.jpg
    09-13-2014 09:26 AM
  2. ahooper239's Avatar
    Bump
    09-13-2014 11:03 AM
  3. KennyMcCormack's Avatar
    There are countless reasons for battery drain. Nothing you provided is suggestive of the problem. You are on cellular. Try switching to WiFi. What background processes do you have running? A lot of these things are hidden under Android System. Try rebooting. Are you seeing wakelocks? Are all your apps up to date? Try installing App Ops from google play.
    09-13-2014 11:34 AM
  1. snapdragon battery guru - is it worth it?
    By iRevo in forum Samsung Galaxy S5
    Last Post: 09-23-2014, 09:55 AM
  2. Replies: 1
    Last Post: 09-13-2014, 09:25 AM
  3. does sun over drains battery
    By bbmjack in forum Samsung Galaxy S5
    Last Post: 09-13-2014, 08:05 AM
  4. Galaxy S3 with sudden battery issues
    Last Post: 09-13-2014, 07:09 AM
  5. Samsung galaxy S3 battery problem, please help.
    Last Post: 09-13-2014, 06:07 AM
