1. AC Question's Avatar
    hey guys.
    I got nexus 5 and it worked perfectly after i change compiler to ART ( but i changed to default ) and after that i rested my nexus to factory default . after that my nexus get worse . battery dies at 5 hours and i don't know what to do.please help.i just got my nexus 2 month !!
    09-13-2014 04:01 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    alighasempoor likes this.
    09-13-2014 04:25 PM
  3. alighasempoor's Avatar
    Thanks.i will
    09-14-2014 01:56 PM
  4. alighasempoor's Avatar
    Here all u said u need...help me plz.i really sad about battery ...
    Attached Thumbnails Nexus 5 battery problem-26953.jpg   Nexus 5 battery problem-26952.jpg   Nexus 5 battery problem-26951.jpg   Nexus 5 battery problem-26950.jpg
    09-14-2014 04:03 PM
  5. mrsmumbles's Avatar
    The first thing i would do is Uninstall messenger.
    09-14-2014 04:35 PM
  6. alighasempoor's Avatar
    After that what u advise to do ?
    mrsmumbles likes this.
    09-14-2014 05:14 PM
  7. mrsmumbles's Avatar
    Nothing because uninstalling Messenger will solve the problem (probably). You could power down or reboot and charge again and see how much better the battery is.
    09-14-2014 05:17 PM
  8. B. Diddy's Avatar
    Your stats actually aren't that unusual. You're on track for almost 4 hours of total screen on time, which is good for the Nexus 5. I usually get around 3 hours. Remember that the screen is the biggest battery drain.
    Posted via Android Central App.
    Please excuse any typos or autocorrect derps.
    09-14-2014 07:38 PM
  9. mrsmumbles's Avatar
    Actually that was more like 4 hours on the charge, with about 2+ hours screen time.
    09-14-2014 08:35 PM
  10. B. Diddy's Avatar
    I said that he was on track for almost 4 hrs of total screen-on time. This is how I figured it. The battery is currently at 36%, and screen-on time has been about 2.5 hrs (150 minutes). He's used 64% of his battery so far. 150/x = 0.64, solve for x. X = 234 minutes, which is almost 4 hours.
    If your screen is on a lot of the time, the battery won't last that long, since the screen uses the most battery.
    alighasempoor and mrsmumbles like this.
    09-14-2014 11:08 PM
  11. alighasempoor's Avatar
    Thanks for response. What about mobile network signal ? Is it usual ?
    09-15-2014 12:59 AM
  12. B. Diddy's Avatar
    Usual in what way? Signal strength depends on your carrier and how well your area is covered. You have 11% time without signal, which isn't horrible, but it's also not ideal. Are you often in an area with poor signal, like at work? If so, you might consider turning Airplane Mode on where you know signal is bad.
    09-15-2014 02:47 AM
  13. alighasempoor's Avatar
    Yeah I'm always in poor network signal area.
    What do u suggest ? Uninstall app that use battery most and turn screen brightness to lowest ?
    There is no better way ?
    09-15-2014 03:11 AM
  14. B. Diddy's Avatar
    Review this guide: http://forums.androidcentral.com/amb...ving-tips.html
    09-15-2014 04:21 AM
  15. mrsmumbles's Avatar
    Oh, I see.
    09-15-2014 06:50 AM
  1. Email app draining battery on Nexus 4
    Last Post: 09-13-2014, 04:36 PM
  2. Replies: 1
    Last Post: 09-13-2014, 04:21 PM
  3. Replies: 0
    Last Post: 09-13-2014, 03:23 PM
  4. My Nexus 5 sends SMS in chinese to my contacts
    Last Post: 09-13-2014, 03:03 PM
  5. problem in call setting
    Last Post: 09-13-2014, 02:26 PM
